Perhaps you can help as I am elderly and new to smartphones!
I have NHS app on my phone and from tyhis I can bring up a QR code for my wife and my Covid jabs - they appear as two separate QR codes for each of us I know I can download them and get a hard copy from my laptop before we go to the airport and I will do this - but I can also make them stay on my camera somewhere say in a file or gallery so that I can easily find them to show at the airport?
At the moment when I get mine I the have to lose them and get my wife's - can I store them together?
In simple terms please. Thanks
Moggie
Simple solution, take a screenshot of the QR codes > open the album app > open the screenshot > tap on the picture > tap on the empty star at the bottom of the screen > it should turn solid white > it will be a favorite pictures > press back > repeat with the other QR code
both QR codes will be at the top of the album app
screenshot > press and hold power & volume down
or
press and hold power button > menu > screenshot
or
Or if you're using a 3rd party app to scan QR codes, I think the app save the photos, depends on the app
Thanks for replying - yes I have found them in Gallery!
Gordon
That's Great. actually any photo that you receive on your phone, you'll find it in the Gallery of the phone.
That worked - thanks so much
Moggie
