Could you clarify, please, what did work for you?
my front camera also soften my image. totally unhappy.
i asked xperia care. cleared camera data, and it works.
Tried clearing camera data, but it did not help at all
Just bought my z3 yesterday, and i hate this soft skin effect. I can't find any fix online. I'm asian and this skin effect is ridic! Even the back camera is doing skin mods.
Can anyone tell if issue is fixed in lollipop?
Unfortunately it's not.
It still takes blurry photos. I really hoped that this will be fixed. 😕
There is a a awful soft skin effect when I take pics whith my xperia z3 compact. does anybody now how to get rid of it?
Yes, you selected it.
Open the camera, bottom left icon. Press it, it will open a menu and you may be able to chose different effects rather than the skin beautify one.
