The sensor in the upper left corner does not work
Не работает сенсор в вернем левом углу
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
Are you referring to the proximity / light sensor?
https://support.sonymobile.com/global-en/xperiaz5/userguide/overview---se/
