I have xperia ZL and the screenshot option in the power button was lost.. is there any way to bring it back? Please help.. Thank you!
use the task menu and then look on mini apps widgets or w.e it is on bottom one of them are a screenshot app that lets you take screenshots again like power + volume down does
make sure that you press and HOLD both keys at the SAME time
i just updated my phone, thanks so much for all ur help!
anytime
