There are a few things you should try first when you experience problems with your device:
Restart your phone to turn off all running applications and to free up memory. Press and hold down both the volume up key and the power key for 10 seconds. After your device vibrates three times, release the keys. The device turns off automatically. After the device is turned off, restart your phone.
Update your phone to ensure that you have optimal performance and the latest enhancements. Read more about how to update and find latest software version.
Reset your phone to its original settings to remove memory blocks: Settings > Backup & reset > Factory data reset > Reset phone Don't forget to back up any important data saved on your phone!
To Enter Safe Mode
1.Switch off your phone.
2.Press and hold volume down key and power button, keep holding till phone boots.
Hi
I like Sony
@pabulo wrote:
Hello, can someone tell me how to start xperia z in recobery mode? I've tried volume up and power but didn't work.
