Last night I had a factory reset on my SONY Xperia ZL, it's currently updated to the lastest version of JB 4.2.2.
My problem is that the album and walkman were updated before the last firmware update but after tomorrow they have rolled back to their respective earlier versions. Furthermore no available updates for them are showing up on the update centre.
that's quite odd, which build number do you have?
you can also sideload them
A repair with PC Companion should also help with this:
To repair the phone software
1. Install PC Companion on a Windows PC from Support
2. In PC Companion, under Support Zone and click Start.
3. Under Phone Software Update, click Start.
4. Click repair phone.
5. Follow the on-screen instructions.
What are your thoughts about this forum? Let us know by doing this short survey.
Thanks a lot, I did not know these apps would be available elsewhere.
Thanks again
anytime
