Hi. I am having problems with priority mode after my update to 5.1.1.
Before the update it functioned perfectly.
I now have issues with it not turning on my interruption settings and it also jumps the sound volume slider so almost nothing when I switch on interruptions once the priority mode activates.
I have it set to come on a bit after I go to sleep and turns off before o wake up.
I have had it set up to only allow starred contacts to ring and notify through. This used to work perfectly for calls, text messages and third party app, watsapp.
No the timer manages to work but it comes on with interruptions toggle flipped off. I then flip it on and have to check the volume slider which jumps to almost silent.
Please help me sort this out.
Thanks
