I think you can get back the pop up notification for mobile data if you go to Settings > Apps > The tab "All" > Phone > Clear data. Note that you might have two of the phone app so clear data for both of them and then restart the phone.
Regarding the notification for software update, I do not think that you can remove it completely unfortunately. It will always appear after reboot.
I am sorry but we have had this discussion several times in the past but we didn't figure out how to bring that back.
@Johan@Rickard Do you have any news on this?
For what we know up to date, a system repair will bring it back.
You could try settings-apps-all,scroll to settings app and clear data. This will revert changes in your settings app though.
@Hampus wanted to suggest the same but never thought it would help as I have told others in the past but none said that really worked. Great, thanks for the update.
