Hello ... please help regarding Mobile was off alone does not work at all in spite of attempts to press the power button with the volume up button and void ... Do you lose data when you repair problems ?? Phone type xperia { z} Please reply as soon as possible
Connect your phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 to 3 hours
If I worked fix problems by Companion program .. Do you lose all the data
Yes, everythign that's on the internal storage will be gone
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
