Hi everyone,
Today I started sorting my pictures and videos. Using my pc I created folder. Being very proud of getting stuff tidied up I opened the "Album-App". I can´t see any folder. In the app it´s still messy.
Is there any possibility to see in this app my neatly folders? Or is there any other app?
Thanks in advance
Sanalsa
Quickpic is cool! Thats how I want to see my albums. Thank You!:smileyhappy:
you can create folders in the root firectory of the sd card and the album app will pick them up and they will be selectable as individual folders or use a 3rd part album app which offers more flexible options - I use Quickpic from the app store and MX player for video I find them a great combination
Seems as if I am little to stupid for the root-thing. I will try Quickpic.
Thanks GeoffH
it works for me - glad I could help
regards
on a side note - pictures are less saturated with colour in quickpic also much better IMO
