There are some car stereos that will only work with apple products, which Sony stereo do you have? have you checked the user guide?
Thank you for your reply,
My sony stereo is CDX-GT54OUI
I can use a sub stick but I like to have my own playlist because of the vast amount of tracks I have, perhaps the head unit is too old for my phone.
Thank you for your reply, it does have auxiliary but still doesn't play, I did use a sub stick for a brief time but it's not easy to find your favourite tracks.
The auxiliary does work as my iPod works fine using aux and usb, I've tried switching from mtp and msc, still not having it, I would rather trade in my stereo and iPod for a new head unit rather than get rid of my Z3, at least I can try before I buy to check it works first, thanks for all your help guys, I just thought there something that I hadn't yet tried.
