My phone is currently stuck after the 10.1.1.A.1.253 update.
I am seeing a screen with "white triangle, with spanner and screwdriver" and have no idea how to get past it. Phone does not reboot even with a hard reset.
Anyone else facing this issue? Any solution to this?
use SUS to repair it
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
for future reference
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
thanks for the prompt reply.
I will run it now and get back soon on the results.
Thanks bro!
it should work
I am at the stage where I am supposed to turn off the phone and plug in the usb cable while holding down the volume button.
Problem is, I can't shut down my phone!
Any ideas?
Thanks again
press and hold power & volume up for few seconds, the phone will turn off
doh nvm.
Got it to detect the phone now. Gonna factory reset. :smileygrin:
enjoy
Works perfectly now. Thanks a bunch!
