Hello,
sometimes my screen flips around like mad, as if I'm moving my finger really quick over the touchscreen, but I'm just pressing it really short. It mainly happens when I play the Simpsons tapped out game, and it also happend the first time while playing the game, but quit some time after I installed it. Every once in a while I have this problem when I'm not playing the game. I have the feeling, that it is happening more often now.
I allready removed my protection glas, because I thought that might have something to do with it, but I still have the same problem.
Any kind of advice?
Thanks
Does the phone has a protective case and/or film? if it does remove it > restart the phone > check again.
I had a glas-film for protection. I allready removed that today. But I did not restart the phone. Gonna do that now and see If I have the problem again.
Hi Horchi, welcome to the community!
To boot your phone in safe mode press the power key until the Power Off message appears > hold your finger on Power
Off for 2-3 seconds until 'Reboot to safe mode?' appears > tap OK. To exit Safe Mode just power the phone off & then on normally. If the issue was not present in Safe Mode, that indicates a third party app is causing the issue. In this case exit
Safe Mode and then un-install any third party apps you don't need and clear the cache/data for the apps you want to keep. If this doesn't help or you have found that the issue was still present in Safe Mode - you will need to run a software repair on the handset.
The problem is not occuring that often. So if I would run my phone in Safe Mode even for a day or two I still could not be sure the problem is caused by a third party app. So far today everything runs smoothly and I'm keeping my fingers crossed.
It seems my problem is solved. I even put the screen protection back on and I am still not getting any phantom input.
