I very every rarely use the flash as whenever I have tried from when i first got the phone until current updates there is always a bluish white tinge to the whole photograph..
Camera seems to work fine with flash off but if i try to use the fill flash or auto flash this happens..
Anyone have any similar issues? I'm getting sick and tired of not being able to use the flash option.
Thanks in advance.
I've seen that before, things to check
Ta for replying so quickly...
1. Nope..
2. Nope
3. Yep
4. Nope.
Will try taking phone out of the case..
Well what do you know.. after all this time.. such a simple thing.. It was the case.. roflmao.. Ta much if i want to use the flash I'll have to remember to take it out of the protective case..
Thanks muchly for the advice..
