I have a Xperia Z3 compact, all working well. but when i get a message the tone or sound only goes once, then stops,, is there a way to make it ring again at intervals ????? my old phone did this, so if i missed the sound the first time may hear it later,, so i didnt have to keep checking if i had any messages... have tried all the tones to see if easier to hear,, but they still only sound once, any help would be appreciated,,, roxane
Hi roxane,
Unfortunately there is no default function that allows this option. You could however try third party apps from the Play Store.
Hi roxane,
I have already received a reply to this, that it is not possible and to try an app from the Play store,,, but where do i find the play store,?????... and what would the app be called,,,,???? any help or recommendations for a ''Non app user" lololol
http://talk.sonymobile.com/t5/Xperia-Z2/Notification-Sound/m-p/965741
You will have to search the playstore to find such app
thank you so much uliwooly, that has been a great help... not easy being app challenged lolol... thanks roxane
