Can't finde microphone noise suppression Z5c (was in Z1,Z3, etc.), wery need it. why it is cutted from firmware? Maybe they put it in new one?
This was answered before in another thread, this option is now ON by default on the Z5 series.
You should find an option called "Mic sensitivity" under Settings -> Sound and notification -> Accessory settings
I now, but its diferent! Nothing common whith noise suppression.
It is true, Z5 generation have the option enabled by default.
Strange, it dosn't shown in meny, it's always on?! Ok but if its on, then it's not working. Because if i listen music in my car, wired connection (aux) and receive a call voice goes in car speakers, people hear road and engine noise, and echo of themselfs Nothing like that in Z1! I have both phones and can compare! Any proves, Of working noise suppression?
You could see this:
/t5/Xperia-Z5-Z5-Compact-Z5-Premium/People-can-t-hear-me-well-during-calls/m-p/1066660#M3921
Thx. For link, i readed it, but there is no any solution. Secondary mic working, i cheked it in servise meny.
Only hope that in new firmware they will fix it.
Now i need to use my old good Z1
