- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all
2 days back luckily i bought C6603 model here in Hyderabad, India. The main difference i found from C6602 model of my friend who took it 2 months back is :
** Camera App is opening faster than C6602
Please help me in the following things:
1. When micro SD card slot, charging slot, earphone slot is opened, the C6602 phone shows alert message to close them which is missing in C6603. How to activate those alerts ?
2. During charging the mobile orange indicator glows, but some times green light glows when it reaches above 80% charging. Why its happening so ?
3. How can i customize the call ringtone, notification ringtone ?
4. Can i delete default ringtones available on the phone or not. If they can be deleted, how ?
5. where can i find the Mobile Bravia Engine 2 app that differentiate and shows the videos/pictures with BE2 enabled and disabled side by side. Like in the Sony executives give demo.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
also check you network settings this may have reset during update - GSM LTE etc
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Just now updated to latest firmware (10.1.1.A.1.253)
My first concern about alert messages is resolved. Background interface is changed to black color. Colors are more vivid.
I got the solution for my 3rd concern too.
Can anyone help me with remaining(2,4,5) things please.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
The led changes from orange to green to indicate that the phone is almost fully charged (i.e. above 80%).
No you can't delete the default ringtones
Go to settings then display in that there would be Bravia engine option just tick mark it
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hello Arjun,
thanks for clearing the things. regarding the bravia engine am aware of enabling/disabling the feature. but i need the app that shows the difference in display with BE2 ON and OFF
check the below video. i want that application. where can i get that
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
There is no app like that available
In the video sony just made the phone play a video so that you can see the difference side by side
That is just to explain the function of bravia engine
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
after updating new firmware... signal reception became weak. Till yesterday the display was showing full signa reception.
after firmware update, phone able to receive only 2 sticks on the signal display.
how to resolve this problem ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
you can use Google Plus and it has a similar BE enhancement
as far as signal most likely that's a network issue. contact them and ask about their network coverage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
till before firmware update it was perfect with full signal, after update it became poor.
as this network is good, i changed to this network 4 months back. so i don't think its network providers issue and again it happened after firware update.
Other than this everything is fine like
camera app opening fast
performance improvement
cool icons
black background, its sexy and beautiful
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
again, network coverage its not 'perfect/stable" from time to time they have issues and that could be the reason here, also it could be an app creating this issue (taskillers, task managers, antivirus) or even a faulty SIM card.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
am not using any of such apps which you mentioned.
SIM Card is 3 days old(its a new SIM) as i was using normal SIM on my old phone.
Anyways i'll check couple of days to see if its a network issue
