I would to know how make work the multi camera app of my Z2 with other xperia devices (z1, zl, m, etc) becasue when I pair with them only appear the files that will be shared, and on my phone only says connecting. do they need the app also?
please your help
Wouldn't it be easier if you talked to them directly?
There should be a way for Sony Mobile to find out which camera supports a feature that Sony Mobile implemented as I believe there IS something in the software that supports cameras and this feature must be based upon some level of exchange between Sony Mobile and Sony Electronics.
If it was a question about third party cameras I would have understood but Sony to Sony communication done by users?
Unfortunately, I do not have any contact person at Sony Electronics. The Multi camera function can also vary, depending on region/firmware and also model of the camera. Thereby, why I'm suggesting that you contact Sony Electronics to get more specific information about your camera and it's specifications.
I have posted this question to the Cybershot communities forum as per the admin's suggestion
Hope that the Admin over there will be able to answer without asking us to find out more from the Sony Mobile division
