Hello,
I've got the following problem:
When my microphone noise suppression is enabled and the Ok Google function, that it works in every screen, my microphone is killed.
If I try to call someone this person doesn't hear me at all. If the person calls me, everything is fine. If I turn off one of the functions I don't have any problems with the calls (in both directions).
If only the Google App is working there is no problem, too. Only the combination of the Ok Google function on every screen and the enabled microphone noise suppression kills my microphone, when I'm calling someone.
Does anyone else have this problem? Does anyone know a solution, except for turning off one of the functions?
Yes, this problem is affecting a lot of users on 5.1.1 with any headset, not only NC headphones. It has been discussed on various topics already. But as far as I know there's not workaround or solution to this issue yet. Hopefully it gets fixed by future Sony and/or Google updates soon.
