You could repair the phone with PCC and that should solve the issue
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Hi ThijsHof,
Welcome to the community,
Following Uliwoolys last post, I have supplied the instructions on how a software repair is performed using a PC and Mac.
Here's how to run the repair on PC Companion:
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
And Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
Hi @ThijsHof,
The software repair will remove all data stored in the phone so don't forget to make a backup in PC Companion before you try the software repair. You can do a backup using the Backup & Restore option in PC Companion.
