I notice that,when the phone temperature is rising up,left channel of speaker plays very quiet.I notice that after update,before everything was normal.
Is that normal?
Phone Sony xperia z3+ dual
You could repair the phone with PCC to narrow down the problem
software repair using PC Companion
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
I've tested the phone.
In diagnostics the sound is evenly balanced.
in service menu *#*#7378423#*#* left channel is very quiet.
when plays the music with player it's loud but only for 1 second and after left channel plays very quiet,right channel is normal.
but it's only when the phone warms up.
This is so weird.
hardware problems or what?
In the safe mode the same situation,left channel of the speaker very quite.
Bridge (for Mac)
Get your phone inspected by your local Sony xperia support .
http://support.sonymobile.com/global-en/contactUs/
Hi @FullMetal
Welcome to the community.
I would recomend the software repair.
Here's how to run the repair on PC Companion:
And Bridge for Mac:
6 . Select your model of phone from the list that appears
You will want to start these processes with the phone powered off and disconnected from the PC.
I repair the phone , left channel still quiet,but problem is solved by using flashtool and clean installation of the firmware.
Thank you for your help.
