You can try settings-apps-all,scroll down to clock and force stop and clear data. You will lose your alarms.
@Larslundblad'
could you elaborate or post screenshots if possible
@Larslundblad
Upload them to box or dropbox and post the link
Which suggestion helped?
Great.
