I purchased the C6602 model mainly to go with T-Mobile HSPA+ but it doesn't seem to work properly. Data speed is extremely slow (50Kbps/100Kbps download/upload) and I only see the letter "E" (for Edge?) instead of H for HSPA on my signal bars.
I've tried all kinds of different APNs but nothing changed. I also tried my sim card on my friend's iphone 4S and it worked perfectly fine with 4Mbps/1.5Mbps download/upload, so the problem must be from the Xperia Z.
Anyone knows how to fix this?
Thanks.
APN: epc.tmobile.com
Proxy: Not set
Port: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MMC: 310
MNC: 260
Authentication Type: None
APN type: default,supl
APN protocol: IPv4
APN roaming protocol: IPv4
(APN enable/disable is check marked)
Bearer: Unspecified
Just as an FYI, everything is listed in the order as it appears on my screen and all settings are exact including case sensitive (in case it matters).
post the APN settings that you have try
Method1
• Name: T-Mobile Data (or T-Mobile US)
• APN: epc.tmobile.com
• Proxy:
• Port:
• Username: None
o Note: For the Username, enter "None" with the keypad. Do not leave it not set.
• Password:
• Server:
• MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
• MMS proxy:
• MMS port:
• MMS protocol: WAP 2.0
• MCC: 310
• MNC: 260
• Authentication type:
• APN type: default,supl,admin,dun,mms
2. Press the Menu key.
3. Touch Save.
Method 2
Proxy: not set
Port: not set
Username: none
Password: **
Server: *
MMS Proxy: 216.155.165.50
MMS port: 8080
MCC: 310
MNC:260
Authentication Type: Not set
APN Type: not set
Method 3
Proxy: 216.155.165.050
Port: 8080
Username: (leave this blank)
Password: (leave this blank)
Server: (leave this blank)
MMSC: http://mms.msg.english.t-mobile.com/mms/wapenc
MMS Proxy: 261.155.165.050
MMS Port: 8080
MMS Protocol: WAP 2.0 (don't know if this is important)
MCC: 310
MNC: 260
APN Type: (leave this blank)
and fiinally, this one from T-Mobile support:
I know its a long shot but what if you get a brand new micro sim card, i know it works with the iphone 4s as you mentioned it above but its worth a try.
Oh it's actually a new sim card that I just activated a few days ago.
Did you buy your Z from the same telco? If not, can you bring the phone to the telco and ask them to check if your phone is compatible with the network?
No I bought it from Newegg.com and I'll try to bring it down to a T-mobile shop later to see if it would help. But I mean, isn't the C6602 model designed to work with T-mobile HSPA+ right out of box?
Ok, T-Mobile shop can't do anything about it. I also called 611 for troubleshooting and they did reset my network connection but nothing changed. Does anyone know what's the best way to contact Sony before I assume this phone's HSPA is defective and return it?
here you go
http://www.sonymobile.com/global-en/support/contact-us/
how about if you repair your phone ?
Update Service (SUS)
http://www.sonymobile.com/gb/tools/update-service/
http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
Alright, I just chat to a Sony Rep and he says that the phone (C6602) will only get Edge with T-Mobile since T-Mobile uses kinda like half HSPA, half LTE signal so the phone's attenna cannot receive full HSPA. That just sucks as I have been using T-Mobile for a long time and I really love the phone.
Now he says that C6602 would work with At&t and its sub-companies HSPA. What are these sub-companies of At&t we are talking about?
