- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have an Xperia Z, with a cracked screen that is not responding to touch anymore.
Tried to copy files from Phone to PC, but I'm not able to see the sd-card or files.
Tried the PC Companion. It sees the phone, but say's it has to be unlocked. Which is not possible anymore.
I also tried MyPhoneExplorer (which seems to have spyware on board according TrendMicro), but also no success.
Please help, because I need my 1100 pictures....
Kind regards, Jelmer
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
my xperia Z screen is broken...how to get the files from internal storage? this is the third time my screen problem!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @arjunthevar
You could try installing ADB, also the SDK has to be up to date, and the USB debugging turned on from your device on the Developer Options. Then plug your Xperia to your computer and from a command prompt (you'll probably have to be in the folder where adb.exe is, most likely something like C:\Program Files (x86)\Android\android-sdk\platform-tools\adb.exe) run this command:
To change command prompt to adb folder:
cd \adb
To pull all files from your device and copied to the adb folder:
adb pull / *in this case USB debugging should be activated on the device.*
Other Commands:
user data only:
adb pull /data
Internal sd card only:
adb pull /mnt/sdcard or adb pull /sdcard
Pictures on internal sd card:
adb pull /mnt/sdcard/dcim or adb pull /sdcard/dcim
Also you can read on this link about the ADB installer:
http://forum.xda-developers.com/showthread.php?p=48915118
Take a look on how to install Google USB Driver in SDK to let ADB see your Xperia device here:
http://visualgdb.com/tutorials/android/usbdebug/manualinstall.php
I hope can be useful.
I'm at disposal for any question.
Best Regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You sir/madam are a lifesaving legend of the highest order.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @foxual
You´re welcome.
If my answer was helpful for you, thank me with Kudos.
Best Regards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi zan,
I have the same issue. Please help me.
My touch screen has gone and I have a password on me phone. I really need to back my data with over 4000 pictures.
My email is
Number
Thank you
Regards
Anisa
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Nisux
Where are your pictures stored ?
Your device was rooted ?
Best Regards,
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
How do you use the mouse to input pin on z1 compact when the screen is black?
