I have an Xperia Z, with a cracked screen that is not responding to touch anymore.
Tried to copy files from Phone to PC, but I'm not able to see the sd-card or files.
Tried the PC Companion. It sees the phone, but say's it has to be unlocked. Which is not possible anymore.
I also tried MyPhoneExplorer (which seems to have spyware on board according TrendMicro), but also no success.
Please help, because I need my 1100 pictures....
Kind regards, Jelmer
OMG i LOVE you right now
Thank you soooo much
its not working. i had connected mouse but it didn't respond
Connecting a mouse with OTG cable can work if you have a broken or unresponssive screen, but how about if you have a dead screen, where you can't see, and connecting via USB to computer goes directly to Charging mode and you can't change to MTP mode siince you can't see the screen?
I have the same problem, but my screen went totally black, how can i mirror the screen to the PC to unlock my phone???
Same here but i have xperia m4 and its screen is totally cant see nothing from it!What can i do? Help
Brilliant mouse + cable
Thanks
You defintely saved me.
Thank you so much! The Camera button worked great.
when i tried to connect a mouse using an OTG connector. the mouse wasn't powered. the phone with the broken screen was an xperia z5 compact. is there something that i'm doing wrong? or..
