I have an Xperia Z, with a cracked screen that is not responding to touch anymore.
Tried to copy files from Phone to PC, but I'm not able to see the sd-card or files.
Tried the PC Companion. It sees the phone, but say's it has to be unlocked. Which is not possible anymore.
I also tried MyPhoneExplorer (which seems to have spyware on board according TrendMicro), but also no success.
Please help, because I need my 1100 pictures....
Kind regards, Jelmer
im forgot my Z3 pattern to unlock, how to reset it?
thanks for the tip with the usb mouse. managed to get access to my cracked z3.
surely sony need to come up with a bettr glass supplier. i have had the z and the z3. still have my original z, im on like my 5th z3 screen cracks and then its useless.
thanks for the tip you saved someone at the sony shop a right mouthful
hi..
I am Dr. Nikhil Shah
please can u tell me the method over personal chat..
i have got same problem in my experia z ultra..
broken screen.. i can see notifications on the screen.. but touch is not working
also there is a pattern lock..
is there a way i can import my pictures and videos.
there were many impotant documents, xrays, reports, and important patient videos in them.
i will be thankful to you if you can help me in the above case.
Thanks
Regards
Dr. Nikhil Shah.
M. P. T., M. I. A. P.
HI,
My Xperia T2 Ultra's Display is completely Shattered. When I tried to connect the phone to a PC, I am getting message as "This Folder is Empty". I can't draw pattern using mouse connected to OTG USB to unlock the phone as the display is completely shattered. Please let me know, How can I copy data from Internal Storage.
Thanks in Advance.
Bala.
my screen has shattered and i cannot access my phone due to pattern lock. please help
i tried with the usb OTG and wired mouse. but the mouse cursor does not show up on the screen
You must have the mouse and otg cable plugged in before turning the phone on or it won't work. I'm going through the same thing right now...
well booting it off/on helped see the OTG Mouse on my Z3+ Dual...
Still cannot seem to get anything but the Google Voice with Mouse and severely shattered screen..
This works, even with a wireless mouse. Thank you!
That does not work for me. After unlocking and changing to computer the program still thinks it is locked. I would gladly pay if Sony could restore information from phone before repairs, or perhaps not delete anything before repairs.
