Does your phone has a SIM card?
Do you have a taskiller or antivirus or clean master?
Do you have another Home launcher?
@ElKatopro If this behaviour remains in safe mode I suggest that you clear data and defaults for the Xperia Home app. You can do this if you go to Settings > Apps > All > Xperia Home.
Note that clearing data for Xperia Home will reset your home screen back to the default look.
