I keep getting a message flash up in my phone saying the headset is not supported change headset or go to sony support page but couldnt see anything. Anyone have any idea what it could be
try to long press on the notification to see which app is causing this. you can terminate that app
Headset not sapoterd
To fix the problem you can use a hands free headset or make sure headset plug has three rubber rings instead of two (the most common). The third rubber ring is for headphones which have a microphone in them for handsfree. The phone is not working with the other headphones because it is trying to recognise a microphone as well.
My phone started to not recognise my headphones yesterday. I had been using the same headphones with this phone for months. I think the problem is due to a software update a few days ago. I was told I should try headphones with a microphone as well (3 ribber rings) by my father who used to fix Sony euipment and it worked.
Hope this helps.
Hi @cameronT
Recently I faced this problem again. When I am listening to music using Headset MDR-XB70, suddenly the volume up or down and when I unplugged the headset and plugged it again, the message that my headset is not supported. Smart connect has already uninstalled. So, I just shut down then turn on my Xperia M4 Aqua (it is not worked when I restart my phone) and I can listen through headset, but the problem appeared again. Is there something else that I can do (except go to Sony Service Center)? Thanks for your response
