Sound comes from the speaker when the headphone is connected. Headphone is not broken. I tried soundabout app. It doesn't work. It's xperia z5 dual
does the headphone has a removable microphone? If I try to use mine Cloud 2 without its mic exactly this would happen, if it has so, I suggest plugging, otherwise, I don't know '-' it can be the P2 type.
No funciona el jacket 3.5, no detecta los auriculares que viene con el Xperia Z5 premium, que se puede hacer?
The 3.5 jacket does not work, it does not detect the headphones that comes with the Xperia Z5 premium, what can be done?
gt
