Try a diagnostic test - dial *#*#7378423#*#* then open Service tests then look for Secondary camera, If it works then you have a software glitch possibly caused by an app but if it fails then I'm sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
