Ok, this would generally mean that this is related to third party software. Can you boot back in to normal mode and see if the issue continues?
Then I would suggest backing up the device and performing a software repair on the handset. This would help resolve any issues that may be related to the issue.
Here's how to run the repair on PC Companion:
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
And Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
Do you have "OK Google" detection from any screen enabled? This might be the problem, to disable it:
- Go to you app drawer -> Google settings -> Search & Now -> Voice -> "OK Google" detection -> Disable "From any screen"
Also if you have any voice recorders installed, try to uninstall them.
When you performed the software repair did you immediately restore the backup file or did you try testing before restoring?
