- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
hi,
i have a ps4 v2.0 and my xperia z3.
the playstation app work great and i can connect to psn but when i click on the remote play button, remote play app opening with this message : error 88001003.
I can't play on my z3...
any idea?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
@geoff37 wrote:i have resolved my problem.
Before my z3, i had a z1 rooted.
I have transfered all my apps to the z3 in particular super su.
my z3 isn't rooted but super su was installed ! and it's him who caused the error 88001003.
i have desinstaled supersu and now remote play work great !
thanks
You're da man!! That was the problem indeed. Fixed! Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hola amigo no hablo mucho inglés pero tengo que decirte que tengo el problema 88001003, y mi móvil es un moto e claro, le instale un framework de sony y luego fuy a la tienda (Play store) y lo descarge después de eso al abrir la app me puso error 88001003 y por más de 30 buscando la solución encontré que si se desinstala el SuperSu funcionaria, lo desinstale y ahora no abre, se pone la pantalla en negro. Vergas porfavor ayuda
Hello friend, I do not speak much English but I have to tell you that I have problem 88001003, and my cell phone is a bike of course, I installed a sony framework and then went to the store (Play store) and downloaded it after that when opening the app made me error 88001003 and for more than 30 looking for the solution I found that if you uninstall the SuperSu official, uninstall it and now does not open, it puts the screen in black.
GT
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
You absolute beauty. First google result. SuperSU was my issue too. Installed it on my z3 but it never worked however I also didnt remove it, and upon upgrading to an xperia XZ1 i had the same error message, tried all sorts, but this instantly solved it. If you can't find this app, look for other super user / root apps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I really dont u de stad the error on my Android tvbox 5.0 can someone please tell me stap by stap what to do..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
No me dejada entra la aplicacion
Don't let me in the application
gt
@Thommo wrote:This will happen if you have rooted your device or unlocked the bootloader or simply modified it in some way
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Plis whats play
- « Previous
- 1
- 2
- Next »
