You know you can add them from google play? There is a + sign.
Well, I am not sure because on my Z2 every small app shows up but I am not on the latest firmware. Can you try to restart your device and check again?
I have currency converter, translate small app and all of those work normally. Tonight I will update to .232 and report back.
Yes, but you can give it a try just to boot in safe mode then back in normal mode. I don't understand why you would have this issue.
