x
Does C6602 work on AT&T
SOLVED
jairaj1979
Visitor
Anyone got their C6602 to work on AT&T?
LTE & MMS??
1 ACCEPTED SOLUTION
Accepted Solutions
Rickard
Master
From what i can see the C6602 will work with AT&T.
C6602 supports the following networks (note that it does not support LTE):
UMTS HSPA+ 850 (Band V), 900 (Band VIII), 1700 (Band IV), 1900 (Band II), 2100 (Band I) MHz
GSM GPRS/EDGE 850, 900, 1800, 1900 MHz
I do however recommend that you contact AT&T to check what standard they use in your area.
2 REPLIES 2
Rickard
Master
profile.country.GB.title
Uliwooly
Expert
it should work with AT&T 850 / 1900 / 2100 (3G)
