For unknown reasons, it looks like posts well within the forum rules, however not too positive about a product (Z3 Compact) that fails for second time 2 weeks after last repair, gets deleted. Moderator should at least have the decency of sending a PM with info and reason for deleting. I guess this post gets deleted as well, however at least the moderator in hiding gets the message!!
There's this tool you have called Profile which shows you where your posts are and if you check you'll see it hasn't been deleted and was merely moved to your other post to prevent what the forum rules state as spamming - maybe you won't read this but if you do then you'll get the message
/t5/Xperia-Z3-Compact/Xperiaa-Z3-Compact-reboots-when-receiving-call/m-p/1045029#M16527
Topic closed
