It looks like you are long pressing the button. When you long press these buttons, it will only display what kind of function it has and therefore, why you receive the popup message with the text "Copy" (this will not copy the text, URL etc ). If you for example want to copy an URL, you only need to tap the copy button and not long press it.
Could you try once agian but just tap the copy button instead.
That sounds strange. Videos can unfortunately not be attached, only photos. You could upload the video to Google Drive/Dropbox etc and share the link.
Unfortunately, I cannot access those links. Could you get a shareable link from Google Drive?
You can find more info how to get a shareable link if you check here (check under "Share a link to a file or a folder"):
https://support.google.com/docs/answer/2494822?hl=en
this shows copy and paste not working on urls
https://drive.google.com/file/d/0B4oFjEhNPrHzaEViZFQ5dWlZRzA/view?usp=sharing
this shows copy and paste not working from standardt ext text https://drive.google.com/file/d/0B4oFjEhNPrHzbFRkM3NLc3pkcnM/view?usp=sharing
fantastic thanks!!!!
You're welcome. :smileysmileythumbsup:
