Hello raul, it seems like you've downloaded some equaliser or sound enchancing app which is preventing you from using default audio settings. Please check for the app and delete it and try again.
Hello Raul, I'm using MX player in my Z3 and it doesn't interrupt my audio settings.I'm pretty sure that equilizer is the one to blame.Happy that it worked out! :smileyhappy::smileysmileythumbsup:
Hello Raul, I just played 3 HD videos in Mx player with both H\W and S\W encodings. They show no sign of interruption with Audio settings of walkman or any other music app. I'm able to change all audio settings which are accessible from Walkman and through general settings. I'm afraid MX player wasn't the cluprit in this case. Anyway Happy that your phone is back to normal. You can go ahead and install and use MX player if needed without hesitation.
