Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
As it says "invalid url" it sounds like the search path for the video might be wrong somehow. Have you tried moving the movies to the internal memory and playing from there instead of the SD card?
Invalid URL should be related to online watching.Where are those stored?
Did you try to move them to the internal memory from the SD card as I advise?
I think it could be related to the microSD.Did you try another card?
Good.
I'm getting the same problem, on Xperia tablet. Video will play for a while, then I get this error. Videos are saved to the internal memory.
