I don`t know how stop panorama. I have experience with other device (Asus tablet) - and here the panorama starts and stops by pressing the shutter.
By my Xperia Z3 Compact (Android 5.0.2.) I have the impression that I need to continue with the movement to end of frame as shown.
It is possible to terminate the scaned panorama manually ?
I have no idea, this has been requested far too many times, and I totally agree with you, it'll be great to create panoramas as we want not fixed to 270degrees.
Make sure to contact Sony with your feedback
http://support.sonymobile.com/global-en/contactUs/
in the mean time there are third party apps on the play store
I'm afraid that there isn't a way to do so, the sweep panorama it's pretty much the same since the Xperia Arc (2011)
It is tragic enough. Setings the frame of the panorama I see as the possible maximum. Must be the possibility stop of the process of making panorama according to the needs. If I stop the movement, panorama, is close, but the format of the original width.
There are some proven SOFTWARE for creating panorama, with which you have a good experience?
Tanks ...
I sent feedback to Sony ... I'll wait
The answer came without meaningful content.
