For some reason after the Lollipop 5.1 update my phone keeps spamming me with a message saying headset not supported the problem I am having is I don't even have a headset plugged.
Don't just cler data on your Smart Connect app, refresh the whole app (with the restart step):
- Go to Settings -> Apps -> Smart Connect -> Force stop, Unistall updates, Clear data, and restart your phone.
- Go to your Play Store and update Smart Connect again.
Hi Liam729,
Welcome to the community,
You could try clearing the Smart Connect data,
Menu > Settings > Apps > All > Smart Connect > Clear Data
Restart the device and see if this helps.
Can you boot to Safemode, this could be a small glitch that may be removed with a different boot.
if it stops in this mode, simply try booting out by power the handset off and then back on like normal and see if the problem persists.
That is strange, you may need to backup the device and run through a software repair. I will supply the instructions below.
Here's how to run the repair on PC Companion:
1. Install and open PC Companion then select Support Zone.
2. Phone Software Update.
3. Start.
4. Repair Phone
5. Continue
6. Accept data removal
7. Next
8. Wait for prepare
9. Select Phone
10. Follow the connection steps
And Bridge for Mac:
1. Launch Bridge for MAC without the handset connected.
2. On the Main Window select "Xperia > Repair Xperia Device".
3. Ensure the phone is charged and select "Ok" in the following window.
4. Select Continue on the following page.
5. Wait until the initialising step is finished the continue as below.
6 . Select your model of phone from the list that appears
7. Follow the connection steps that appear, ensuring that you are holding the relevant button down before during and after the connection phase until the update/repair begins.
