Mengapa menu hard reset tidak tampil, hanya layar hitam dngn led blue ?
Why is the hard reset menu not showing, only a black screen with blue LEDs? - GT
Hi @rojikin-jh, welcome to our forum!
Your question has been translated to English as this is an International forum, please post any replies in English and it will be easier for me and other users to assist you.
If you are looking for a recovery menu, there is no such menu in our devices and you will need to use the factory reset function found in the Settings menu, or if you for example have forgotten your screen lock, you can perform a software repair using Xperia Companion.
Note that all data stored on the internal storage will be deleted when you reset the device.
I hope that helps!
