Hi , I have just upgraded to the .434 update and now whenever I go to the bluetooth settings from the system settings it immediately FCs , I can now get my phone get into bluetooth discover mode , any help pleaes? I restarted and also did a repair but still same problem
Have you tried making a repair of the phones software using PC Companion? Perhaps something went wrong during the update and a repair will help in that case. I tested several phones here with 434 and can't replicate the problem either.
Regarding model selection in PC Companion there's no problem with selecting another model. PC Companion will identify phone and customization when you connect it in flash mode so you can't get wrong firmware installed.
i updated also and have no BT issues
The problem is I have a C6603 and the website or PC companion has only 6602 to be selected for model . would this have causes proble,m ?
go into the services menu and see what model it's reporting in there
still says c6603
