Bluetooth artist/album/track info from WIMP is not shown in the car display when playing. Sometimes the info for the first track is shown but not updated when playing next track, other times "no artist/album/track info".
Is this a known issue/bug in the SE 4.4.4 kitkat?
It works on other phones with 4.4.4 kitkat.
Kind regards,
Rune
Hi guys, with the last update (23.4.A.1.200) this problem is now FIXED :smileysmileythumbsup:
We don't have any known issue with AVCRP. What happens if you try other players like Walkman? As i understand it, it's the app/player that needs to support AVRCP 1.3 properly.
tried with another ROM (Cyanogenmod 11) on the Galaxy S3 and it works flawlessly. Not so on Z3. Obviously, the application is not the problem. Doesn't Z3 support AVRCP 1.3?
Rune
Rickard, do you know if avrcp 1.3 is supported by Z3?
Z3 does support AVRCP 1.3 so this is a bit strange that it doesn't work. Could you please send me a PM with the following information:
Name:
Phone nr:
E-mail:
Country:
Operator:
IMEI nr:
Build number:
Same result with Z3, using Walkman App, Power Amp, and Rocket player. Pandora song and artist information updates, but none of the other apps. The vehicle is a 2014 Mazda6.
I have the same problem. I own a 2014 Mazda CX-5. With my previous Samsung S4 Active running 4.4.3 it worked perfectly. Now with my new Sony Z3 compact, I can see the name of Artist/Album/Song of the first song I play, when I change the song by skipping forward or when song finish and the next one starts, the displayed name is of the first song and it stuck this way. only when I move to radio and back to bluetooth, the name of the song is updated. This is very frustrating...
