I have Volvo V40 and when I step in my car with my bluetooth enabled already, I see on my Z3 Bluetooth connect sand then disconnect. This repeats all the time. When I then disable bluetooth, wait a while and enable bluetooth again, the problem is gone. I don't know for sure, but what I have see on my car's phone menu, although I get these disconnects on my phone , the disconnects are not noticed by my car. But again, I didn't look into that yet. Do you have similar problems?
I disagree. This is a Sony issue. I used a Samsung between my two Sonys, which had 4.4.4, and it worked perfectly.
I have a new Volvo, as I already described, from 1 October 2014. They SAY it is compatible and it does work, only the phone keeps saying it connects and disconnects. Although it stays working. Just put the Volvo Audio system on Media(Bluetooth) once and it stops disconnecting/connecting. Even if you then switch to Radio or other source.
At home on the surround system I'll contect my Xperia X3 Slacker Radio via bluetooth to my surround system. it then proceeds to stutter my music. My girlfriend connected her Iphone with the same slacker account, and all worked fine. Is there any solution to my problem
