Hi @stexi
Based on how you mentioned you are using it, this does sound about right. Keep in mind that if your screen is constantly active, this will be the biggest drain on your battery. Couple that with audio and internet usage you will see roughly the drain you described here.
You can check what apps/functions are using the battery by going to Settings > Power Management > Battery usage.
Hi @stexi
