Settings > apps > all > smartconnect > clear data > restart the phone > check again. Also check if there's any dust or anything else inside the 3.5mm audio port
Hi @giedrius1
Please, check your audio configurations in Settings -> Sound & notification -> Audio settings. Also boot your device into safe mode as explianes here. If the issue was not present in Safe Mode, that indicates a third party app is causing the issue. In this case exit Safe Mode and then un-install any third party apps you don't need and clear the cache/data for the apps you want to keep.
