I've an undocumented status icon that has appeared. It's the far left icon (next to the silent speaker icon) in the screenshot below.
Thanks...
I've just disabled/enabled stamina mode and the icon has re-appeared.
Icon represent your stamina mode is on. You can't remove that icon without turning off your stamina mode.
