Android
What is the android in z3 compact now? What update do you need to upgrade to? I have 6 worth. Thanks.
Андройд
Какой сейчас стоит андройд в москва z3 compact? До какого обновления нужно обновить? У меня 6 стоит. Спасибо.
I've edited your post as this is an English only forum, you can use Google Translate to reply and/or post.
The last update is/was Android 6.0
Hi @Lekd2010, welcome to our forum!
As @uliwooly mentioned, Android 6.0.1 is the latest Android version for the Xperia Z3 Compact and I since it stopped receiving updates a few years back, I'm fairly sure that it won't receive any more updates.
Most applications should still work on Android 6 though and it's more Android 5 and earlier where you can experience that applications are no longer supported.
Have a nice weekend!
