x
android os drain battery
SOLVED
hector121
Visitor
After the last update I notice that my battery drain so fast
l found on battery usage that android os drain more than 50% of my battery
I used gram program to know what exactly causes this issue
I found that kernel drains my battery
I connected the device to my pc and used SUS to repair it but nothing happened after the repair
Same issue remains
stamina mode doesn't make any changes
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.GB.title
Uliwooly
Expert
try this
repair your phone once more, but this time do NOT sync any account, do NOT install any app, uninstall mcafee and use your phone for few hours, check if the same battery drain continue.
6 REPLIES 6
hector121
Visitor
i just want to know if that is normal with the last update and it will be fixed in the next update or some thing is wrong with my android system ?
i found this issue common with other devices but not with xperia z
i went today to sony service center and they told me you have to leave your mobile to instal a new software
but if that is common with other user ill wait for the next update
please i need a solution and forgive me for my poor english
Uliwooly
Expert
try this
hector121
Visitor
i already did what you said accept removing mcafee
hector121
Visitor
ill repair it and ill remove mcafee this time
ill replay after testing this try
Uliwooly
Expert
let us know how it goes
vkmxpz85
Visitor
i am having xperia Z & past few hours i have updated from 10.1.A.1.350 to 10.1.A.1.434....one thing i observed battery drains too fast.....previously not happening.....
