Good evening I've just bought a Sony Xperia Z5 Premium and it's my first time. I've downloaded some app such as ASmart IR, Smart Remote and etc. but it didn't work with my air con... I love to learn new things so could you give me some advices or informations? Thank you very much
Hi @TTuTT,
As alexdon pointed out the Xperia Z5 Premium does not feature an IR blaster. So unless your air condition unit is able to connect to a Wi-Fi network and there are a dedicated app available for your unit in Google Play that allows you to control it I don't see a way this would be possible unfortunately.
@TTuTT There isn't an IR blaster on the Z5P so you can't control the air conditioning.
Hi @TTuTT,
